hey Cuz, you MAY find a couple(four actually) metric bolts. The front caliper mounting bolts, were upgraded to Metric, later in the life of the 6, if I remember correctly, somewhere in mid 74. Other than that, all British,
A quick discourse on sound generation of the brake pads.
The squeal is caused by movement and vibration. The pads should be lubed with a good high temp grease anywhere the metal(not the braking material) of the pad comes in contact with the caliper and retaining pin. On the ends of the pad, and on the back of the pad where the pistons meet the back of the pad. A lot of companies DID go to a silencing shim(but the industry has pretty much gotten away with those now) that would absorb some of the minute movement of the pad metal against the piston and act as a damper. Also a good idea to put the high temp lube on the opening holes of the pads where the pins go through, so that the contact of the pin and pad backing plate are lubed.
The material of the pads of the first poste(squeal like a pig) may be contributing to the noise also. Most new pads come with a beveled edge on the top and forward facing edge of the pad. Reason why, is so that the brake dust has less of a chance of building up on the leading edges of the pads and rotors. Often in cool, humid climate(Pacific Northwest and Easte Coast) when you go to reverse a disc braked car and step on the brakes you may be met with an initial squeak, which is the cool brake dust being caught between the pad and rotor.
As for our "squeal like a pig" poster. If the pad is lubed(also Permatex, BG and a few other companies) made a brake pad lubricant, that may help to alleviate the noise. But I have found that "cheap" pads the friction material is such that some noise is almost always present.
So, lube the metal of the pad(try to lube the friction material if you have access to the BG(make sure you let the pad dry for at least a couple of hours before applying the brakes) bevel the leading edges(front and upper corners) of the pads, make sure you wheel bearings are tight. And you should have no more brake noise.
