sparkydave
Well, I thought the coolant change was the last thing the car would need for a while, but a little squeal in the front seems to be getting worse. I was wondering about the so-called "anti-squeal shims" in the front calipers. My car only has one on each side, but Moss shows there are two. Would the addition of the second shim make a difference? Basically, when I have the brakes on lightly there's a squealing, but if I brake harder it goes away. I may just bite bullet and replace all of the pads, since one of the rears got a little oil soaked, and I'm pretty sure the pads are all original. Should I go ahead and order two more shims along with new pads?
