As I've gotten more experience driving Baby Blue, I've come to learn the myriad of sounds she makes and knowing what is a "good" sound and what is a "not so good" sound. Taking Jessica on a long drive yesterday, the car acquired a squeaking noise coming from the front end. It definitely was not motor related as the squeak was a function of ground speed, not engine speed, and it wasn't consistent.
Inspecting the car this evening, I found one relatively loose lug nut on the left front, and three of the others could use some tightening. So, I went around the car and checked and found a few others that had loosened up. I'm not sure if that was the source of the squeaking. The other thing I found is when I grab the front wheels, there is some lateral play. Not enough to be hugely significant (I think), but enough to be noticeable. Is a little bit of play normal? I'm thinking when I repacked the bearings last winter and put it all back together, I may have not cranked down the retaining bolt far enough before inserting the cotter pin.
I was hoping to make it to December before I reopened the front end to do a repack, but if this play is not normal, I'll have to work on it now.
