bugedd
Hey all, hoping I could get some advice on the car sputtering. Last winter I took the HS4's off the car to replace the header, pretty remedial. I put it all back together and I seem to get some sputtering where I never had it before. The car did sit for some time, we had a wet winter, then it went from rain to 112 degrees. So the car had only been driven half a dozen times this year. Anyhow, it did it very lightly, more like just cutting out at higher revs with my foot in it. Yesterday I took it out and under moderate acceleration it hacked pretty bad, then it would clear up and drive fine, then accelerate and it would hack. Guessing carbs as its not consistent, and the idle, start up, and steady throttle are smoooooth. The gas is new....thoughts of what to check?
Hi Guest!
