Sprite ID numbers
Highpockets1
New member,not sure if questions about this car should be limited to here or can be posted in the AH forum?I posted in the Austin Healey and new member forum.I was wondering if someone could tell me where to locate the ID numbers on this car.....Thanks
There should be a plate on the front chassis rail below where the carbs are (at least on a Bugeye).
vehicle number is on the left hand front of frame inside engine compartment
engine number is on the right hand front of the block
crankcase number is on the left hand side of the case.
after you find them just post the numbers here, somebody will love having the chance to tell you about them
There is also a year or style number (GAN, HAN etc.) stamped on the right hand side under the front damper
Mark
