This is a question that has a lot of answers, so here is my input. The best you can do is an open header. Now, some will tell you otherwise, but the key is properly tuned carbs to your exhaust backpressure. Since an open header isn't possible, Anything less restrictive is better once you get the carbs retuned. I'm running a 2 3/4" system, and had it on a 1275 before adding the SC.
