tosoutherncars
Hi all,
I've got a summer driver, a 1500 with some mild mechanical issues that I want to sort out for this summer. "Milo" is an underused, but generally sound Northern California car (approx. 90k miles) that I drove from CA to Ontario last summer. The body is in very, very good shape, the biggest flaws being dents in front of each door where a S.P.O. removed the check straps.
It made it back home, from California to here in Ontario, but the ignition and the horrible Z-S 150CD carb both showed problems. As well, the front tires showed heavy wear on the inner sides, symptomatic of bearing collapse. Also, the clutch slave cylinder sprung a leak, and a rebuild kit failed to remedy the problem (the inner cyl walls were fairly scored).
Below is the beginnings of a write-up of my plan to get it ready for summer fun.
<span style='font-size: 17pt'>Preparing the Midget for Summer '07 </span>
<span style='font-size: 14pt'>Major Tasks
- Front Suspension Rebuild
- Intake Manifold & Carb Replacement
- Ignition Replacement
- Clutch Slave Cylinder Replacement
- Full Tune-Up
- Interior Spruce-up</span>
Parts needed (marked X if bought)
[X] full polyurethane bushing kit
[X] full kingpin set
[X] full trunnion set
[X] brake lines (Goodridge stainless)
[X] rubber gaiters
[X] tie rod ends
[ ] rotors
[ ] pads
[X] wheel bearings
[X] Weber 32/36 DGAV downdraft carb (used)
[X] Cannon intake manifold (installed)
[X] carb rebuild kit
[X] manifold gasket set
[X] tubular exhaust headers (4/2/1)
[X] Fuel pressure regulator (adjustable)
[X] new distributor
[X] optical pickup (to replace points)
[X] Luminition ignition coil
[X] wires
[X] plugs
Clutch Hydraulics Replacement
[X] Clutch master cyl.
[X] Clutch slave cyl.
Full Tune-Up
(some parts as above)
[ ] Oil filter
[X] Air filter
[ ] valve shims
Interior Spruce-up
[X] New carpet set
[ ] headrests
[ ] New Haartz canvas top
I'd love some input, whether it be items I'm missing, other jobs you would suggest as the season approaches, etc.
-Duncan
- Full Tune-Up
[X] rubber gaiters
[X] tie rod ends
[ ] rotors
[ ] pads
[X] wheel bearings
[X] new distributor
[X] wires
[X] plugs
Full Tune-Up
[ ] Oil filter
[X] Air filter
[ ] valve shims
Interior Spruce-up
[X] New carpet set
[ ] headrests
-Duncan
