I don't have one so I made my own, kinda. I found a grade 8 all thread and cut a length about twenty inches. I put one end up through the shock mount and double nutted the top. Put the spring in place and used a three sixteenth plate under the lower spring mount. Held the top nuts with vise grips and tightened the bottom nut. Worked like a charm and I felt safe using the grade 8 all thread.
i did use a bottle jack to push the lower A-arm up to make the rear studs easier to install.
Hi Guest!
