I made my own using a 5/8" bolt from the hardware shop. I have now used it on about 10 springs and it is not showing any wear. I tried a half inch bolt before that and it did not hold up. I posted some pictures of it on a thread just a few weeks ago.I'm curious, do the simple Moss Motors "huge long screw and plate" design spring compressors last forever, or do the threads start to wear and allow the nut to slip? I've used mine a few times and I seem to notice some thin shearing of the steel around the threads. Anyone notice the same?
Charley
Thanks Charley,
I've been searching for at least a drawing with dimensions of the bottom bracket I've seem some make with the holes that go over the studs and a hole in the middle for the bolt. I have a buddy that can plasma cut and I'd rather give it to him once to cut than have to go back and forth cutting. I've seen some that don't have the holes and simply rest on the bottom. Overkill, but I'll probably go with 3/4" rod and just make my own. I've got a feeling that I'll be adding spacers to the new springs so having my own will probably be better.
Kevin
