Andrew_Grannis
I am starting the slow and tedious process of tearing the car apart and am continuously rediscovering the laziness of the previous owner. Today I went to remove the grill but the screws were simply spinning with their nuts on the other side. I figure ok, remove the splash panel in the wheel well. Unforunately, it seems the previous owner decided that since the screws were very rusty, he would just undercoat over top of them and make it look nice rather than fix it. I think the screws are beyond being saved but am wary of drilling them out as it seems they screw direcly into the frame. Is this correct?
Facing un-screwable screws, how would you all go about removing them?
Thanks in advance!
BTW: Both the front and rear bumpers are available if anyone is interested and are in relatively good shape with no major dents although the finish needs some work. They both have their overriders in place as well as their brackets (i.e. spring bars). The BJ8 doors currently on the car will also be availble once it is determined they are no longer needed for structural support
Thanks in advance!
