When using poly bushing to replace the original do the wishbones rotate around the poly bushing or around the bolt that goes through the bushing and mount?
The original rubber bushings were tight in the wishbones and it appeared that rotation was around the mounting bolt. The metal bushing inside the rubber bushing allowed the rotation around the mounting bolt.
With the new poly bushings, they seem to fit looser and I am wondering if when installed and the mounting bolts tight, the wishbone arms won't want to rotate around the poly bushing OD.
Also what gets greased to prevent squeaking? OD of bushing, and or between bushing and metal bushing?
Obviously grease would be a good thing between mounting bolt and the metal bushing.
