bobmga62
Hi
Today Installed my engine and rebuilt transmission into the spit.. after locking everything in , I placed the shift lever on the the transmission (this is a MKII) and no matter what I did the box seems locked.. no movement or ability to shift gears.
Clutch does work, when depressed, driveshaft spins freely, when out, car is presently in gear, so locked up.
I removed the shift lever a few times to ensure I had it located right, and all seems good, I have done this job many, many times without ever experiencing this problem.
I did shift the transmission into a gear when I mounted onto the engine, keeps spline from spinning when mating to the clutch... at that time appeared to shift into a gear easily...
One last small point, which may be doubtful to the problem, there is no oil in th gearbox as yet, been dry since being shipped to me a few month s back
any ideas would be gently appreciated
thank you
thank you
