Spitfire Spitfire Timken wheel bearing numbers
Norton47
I am rebuilding the front end on this spitfire and with the wheel bearings out, there aren't any numbers on the bearings which I thought was strange. Anyway thinking I might as well replace, but don't want to get poor quality.
Does anybody have Timken part numbers or other good quality bearing numbers?
Thanks
The bearing numbers I have are: Inner Bearing 07100S, Inner Race 07210X, Outer bearing 03062, Outer race 03162.
There is also a rubber seal available to use instead of felt. The part number I have is 340823, but I'm not sure whether that is a standard number or just the part number General Bearing here uses, but a bearing shop should be able to cross reference based on the bearing numbers.
Don
I am not sure, I was going to call Monday.
