dklawson
I have determined that the play in my project '72 Spitfire's steering is in the coupling just above the rack. (You can see play in the joint when the wheel is turned or when you push/pull an elevated road wheel).
I had always thought those couplings were something like a piece of reinforced tire rubber or similar. The manual makes it look like the disk is metal and that there are rubber bushings between the bolts and the disk.
Can one of you describe which construction is correct and if there are any pointers on how to easily fix this... please share the details.
Thanks.
Thanks.
Hi Guest!
