Flatlander
I purchased my 77 Spitfire last fall and drove it for a short time. It seemed to run good except for needing usual maintenance caused from neglect. Since completing this work I have been chasing a stalling problem. Typically it would run for a short period of time then die. After a period of time (10-15 minutes) it would restart then do another distance and die again. The distances and temperature variances at the time of failure lead me to believe that the problem isn't temperature related. I believe it isn't ignition related as I wired in a timing light and at the time of failure was still getting spark. So this to me leaves the fuel system as the problem. I have done all of the following in the last few months prior to and after this problem manifested itself:
Replaced coil
Replaced plugs, points, condenser and ignition wires
Replaced fuel pump
Replaced and/or blew out all fuel lines and filters from tank
Rebuilt carburator
I am now at the tank. Earlier this summer I had removed the tank to drain all of the old gas and replace the fuel sending unit. A visual inspection of the old gas and what I could see through the only openings in the tank led me to believe that the tank was pretty clean (Arizona car). I have noticed that blowing air back through the supply line from the tank is restricted if the gas cap closed but clear if it is closed. (This is using my own air power as I was concerned about blowing compressed air possibly making the matter worse.) The vent line from the small black canister on the vent line from the tank to the engine compartment is clear. My question is:
What is that black cannister on the vent line at the tank?
Shouldn't there be free flow of air through it?
Side note; At the time of my car dying I have tried opening the gas cap but still was not able to restart though if the car had rune out of gas then maybe I didn't try long enough to refill the fuel line.
Any help would be appreciated. Also has anyone seem a web site that dealt with the calibration of fuel gauges? Seem s like I have seen one but can't find it again.
Thanks,
Gary
Replaced coil
Replaced fuel pump
Rebuilt carburator
Thanks,
Gary
