hello all,
I have recently noticed that my passenger tire leans in more than the drivers tire. I know that they usually lean in at the top but im not sure if they should both be the same amount or is its ok if they are different. I put a level on the tire and the drivers leans about 3/4" from top to bottom. The passengers leans about 1 1/4" from top to bottom. Just wondering if this is normal and if its not what might be my issue.
Second issue when im driving I can hear a noise coming from the back and it sounds like the drive shaft u-joint. Its speeds up as i go faster and it sounds like its rotational. If I take off kind of hard I can get a small clunk. Is this the drive shaft u-joint? Does it just need to be greased or does it need to be replaced? I tried to grease it but the nipple is so far in I cant get the grease gun on it to grease it.
thanks here is a pic of the car back together after I painted it. You may remember i recently posted pics of my first diy paint job. Thanks everyone...
Hi Guest!
