Hello, I am new to the Triumph world and need a little help. I have a 1975 spitfire that is in good shape now (at least I think it is) but, the guages show that it runs near hot after I drive it about 10-15 miles. When I turn it off, it does not boil over, hiss, or pop but I just can't get comfortable thinking it is a guage issue. I have done the following so far to address the heating issue:
1) took out the thermostate in case it was faulty since a thermostate can restrict water. Thought being without one there is nothing to cut off water supply.
2) drained the coolant and put in a new 50/50 mixture of Preston coolant/antifreeze.
3) verified that the fan and belts are functioning (appear to be)
4) water pump doesn't vibrate or leak
5) checked to make sure the "shrouds" around the radiator are properly in place and they are.
What else could it be??? Does the large license plate mounting cut off air? Do I need to put something else like "wetter water" from Redline in it? ANy help would be appreciated. Thanks, <font color="blue"> </font> from the newbie.
