Trevor Triumph
I installed a new wiring harness in my wife's MKII Spitfire after letting a lot of smoke out - burned / heated / melted the red circuit from the left rear lamp to the front of the car, under the dash. The folks I bought the harness from suggested adding a fuse in the red circuit. Since electricity is really a magical art, are there any suggestions in placing the inline fuse?
Since the harness is new, my neighbor, a car guy also, suggested relays for the headlights. I found a diagram, but I don't know exactly where to install the apparently two relays, high and low beam, where to cut the wires, and where to open the vinyl tape to get at the headlight wire.
Other problems: the overdrive is not operating at this time, and the gas gauge has issues - registering a full tank.
Trevor Triumph
Trevor Triumph
