Spitfire Spitfire key/locks?
frankenstang57
Question for you guys about locks on a Spitfire. Is it one key fits the ignition and doors or was it multiple? I'm to the point on my JPS to install the steering column. I never got a key with my donor car. I swapped out the column with a one from a '74 to test drive it before I disassembled it. I had to jumper a bunch of wires since they changed the wiring harnesses between '73-4. Anyone ever remove a ignition lock without a key? I haven't really looked at it yet, just looking for some inputs!
On the later Spits it is one key for both door and ignition. I think the same for '74. A separate smaller key for bootlid lock.
You can get the ignition lock out without a key. Triumph protected the ignition lock by using 'break-away' hex-bolts (shear-bolts) that hold the lock in place under the steering column. To get them out you need to either drill a hole in them and use an easy-out, or get a chisel or something to drive and loosen them or make a slot for a screwdriver.
Once these bolts are out the ignition switch and lock drop out together.
I think earlier models (with the key and lock down to the right in a separate shroud) you may have to drop the steering column to get at the shear-bolts, because I think they come through from the top. On later models where the key goes in higher on the rh side, I think you should be able to get at the lock bolts from underneath.
