Welcome to the forum!
I strongly suggest reading a quick primer on SU carburetors... SUs are constant depression, or constant velocity variable venturi carbs, which means they are totally different than your standard carter, weber, or holley. Essentially, the fuel pump pushes fuel into the bowl on the side until the float reaches the top. The fuel in the bowl goes through a hole to the other side, and as the throttle is pushed -- the butterfly throttle opens, causing the piston to raise. On the piston is a little tapered metering needle -- so as the piston goes up, fuel is allowed to pass around the taper and up in the venturi area and pass the butterfly valve into the manifold.
SO...if the fuel is spilling, likely it is from the float bowl because the grosse jet is stuck open.
Now this all probably seems really confusing, so the first thing to do is get yourself a Moss Motors catalog, which has an exploded view of the carb (or go to
www.mossmotors.com -- they have it online.)
But in actuality, a 10 year old can rebuild SU carbs. They are extremely simple in terms of number of parts.
So simply unbolt the float bowl top (the small bowl thing on the side.) Pull up and see what is inside, and if pushing the float up closes the jet. The other thing is that the float might be set too high, so the bowl overfills.
It is also possible that the seals on the jet itself (what the needle is surrounded by) are gone, so the fuel is leaking. If fuel leaks from the bottom of the main section of the carb, that's probably the problem.
Although, I could be wrong, and someone might have a different idea.
The best way to understand SUs is to simply take them apart, clean them, and put everything back together! That's what I did with my TR3 and I was amazed that I could do it with such novice mechanical skill!
By the way -- were you the one I suggested join the forum from the Ebay listing?
