Spitfire Spit front shock top nut
cutlass29
Finally getting around to replacing shocks on front. This is what I'm taking out...
this is what is going back (spax adjustable and new spring)... but can't find a torque spec anywhere for this nut...any ideas??
There is no such spec. given even in the factory workshop manual. But perhaps the point is moot, since a: you're going with not-quite-stock components, and b: perhaps the only "critical" thing here is that the two nuts be jammed together so that there is no chance of them working up the threaded shaft.
Sorry I can't help more....
The bottom nut should be tight enough to slightly compress the bushing. All you really need to make sure is that there isn't wiggle room (in the bushing) when it is installed or it will start making a clunking noise as the shock bangs around in there.
- Thanks for your prompt response guys.
- will plod on with it this evening.
- The Mrs. doesn't like it off the road too long...get fed up hearing " Can I drive it yet?" every time she comes in the garage. She's worse than the kids on a long car trip...you know the one "are we there yet?"
I know the feeling... /bcforum/images/%%GRAEMLIN_URL%%/smirk.gif
Question: Where did you get that spring compressor?
- ebay purchase from the UK. Guy called Ian over there makes a few different "devices" and parts for the spitfire.
- I tried using the 2 piece hook type found in most of the stores over here. Scared me to death once there was a load on the spring. Even with the extra hooks in place the whole thing started to twist off the spring. This one's not too cheap but works a treat, and more importantly, safely.
- I also have one of his hub pullers. I didn't get this one direct off him. Someone in the UK bought it from him, used it, and then resold on ebay...to me.
- I'm lucky in that these are quite heavy items and would cost a pretty penny to ship from England. I import/export product to and from the UK all time so these things hop a ride with my other products.
