Spitfire Spit 1500 Thrust Washers?
owensdad74
Greetings All,
I have a 1500 I'm planning to rebuild, and need help sourcing high quality thrust washers (bearings).
After reading on other forums, this is the place to find the parts and the know how to install them properly so as to reduce failure.
If anyone knows where to find them, I would greatly appreciate it!
Thanks in advance,
Brian
I replaced the TW's on my TR6 in the spring. Check out the TW that Scott Helms sells; he is a pleasure to work with and his TW's are made from a better material than you can get as stock.
www.customthrustwashers.com
Welcome to the BCF!
Note: Not sure if Scott sells them for the Spit, but it does not hurt to contact him to find out.
We just crossed paths in cyberspace
A friendly thank you to you as well Elliott. I will contact him tonight to see if he makes the washers for the 1500 Spitfire.
Welcome to the BCF!
Hey , when did this top posting start.
AHHHHHH!!!!!
What top posting? :devilgrin:
AHHHHHH!!!!!
