bt7tricarb
O.K. - now that the trafficator issue has been raised, I'll start with a new one...
During the restoration, my speedometer was sent out to be re-done. None of the faces of the guages seem to have been re-silkscreened, but that's another topic.
Two things on my speedometer now.
1. The speed is fairly accurate up until close to 60 MPH, then it's significantly off (as much as 8 - 10 m.p.h. when over 65 m.p.h. - ex. - when my speedometer shows that I'm close to 80ish, I'm only going 72). I did have my OD changed from 20 - 28%, but I thought the shop owner that did my car told the person who went through the guages this information. Is this just something most everyone experiences?
2. The gauge still has quite a bit of "bounce" to it. Instead of being nice and steady, the needle bounces between anywhere from 5 - 10 miles an hour, degree wise (i.e. - if I'm going 60, according to my GPS, then the speedometer will "bounce" between 55 - 65). Does anyone else experience this? I just thought that on a rebuilt guage this would not be an issue. I also wondered if it could be something in the cable...
Hi Guest!
