Speedometer Cable Routing
66 BJ8
Hello
There are two holes in the fiberglass transmission tunnel
and i cannot remember which one i shall use for the speedocable. Can someone help me??
Regards 66 bj8
Re: speedocabel
There is a circular hole at the very forward part of the transmission tunnel, in the center, that the speedo cable is suppose to go through. This hole is forward of the rectangular hole that is used to check and refill the tran oil. Victoria British sells a rubber plug that fits in the hole that the speedo cable passes through. Moss Motors shows that plug as unavailable. Victoria British is located in Kansas, USA, www.victoriabritish.com
Re: speedocabel
/ubbthreads/images/graemlins/laugh.gif Bj8, If you do not have the grommet that fits in that round hole,spares are available in Denmark and Sweden via the Clubs or from stockists in the UK-FWIW___Keoke /ubbthreads/images/graemlins/driving.gif
