Hi Guest!
Anyone know if there is a Speedo drive gear available that would give a more accurate reading for a 19/41 ratio diff on a sprite. The std one looks quite expensive from some suppliers so it would be good to get one that does the job more accurately.
There ARE different drive gears available.(at least for the DATSUN tranny) Paul A. had someone in Portland Oregon (a speedometer shop I believe, but can't recall the name) he had them custom made depending upon which diffy and the size of tire one one going to run. ...
That said, I had changed the diffy from when I had the tranny changed. At that point the error in speed was different than the error in the odometer. One was at 15% and the other at almost 20%. ...
Going to ABFM this year? I'll be there.
