Thanks you guys for posting. The treads on the brass sleeve had a deep scratch and I ended up forcing the knurled nut on with channel locks. I just hate doing that even with some protection on the jaws of the pliers; it chewed up that soft aluminum. The sleeve must have got wacked when I put a clutch in back in 93 and I just let it go. I was going to swap in a better sleeve, but the area was just too tight, and I was fearful of opening a can of worms and have to pull the tunnel or whatever. I did get the sleeve to move out about a ÂĽ inch by prying with the screwdriver, and then I thought I would never get the new one to line up, so I opt for cavemaning the knurled nut on, but every turn hurt. Then after I was done, I noticed there is a square notch on the end of the brass sleeve, so perhaps I could have got it all back together with the trans in place, just too tight.
