bob hughes
Hi Guys
Finally got around to making the new trip meter reset pin as a spare could not be sourced from anywhere over this side of the pond ( plenty of offers to recondition the unit though).
I am now stuck as to where the new rubber seal goes in relation to the bezel, glass, glass holder, casing assembly. When I dismantled the unit in the first instance, there were no rubber seals present just a hard mastic, so I ordered some from AH Spares. Two seals came - one a round section - and the other a square section. I believe that the round section fits over the casing to sit against the dash board and that the square section is the seal for the bezel/glass. I have tried it directly under the bezel - the assembly is tight, but the glass is loose. I have tried assembling the bezel, the glass and the glass holder face down on the desk and inserting the square section under the bezel lugs - a tight squeeze but it holds everything together, however trying to fit that onto the rear casing is a nigh on impossible.
I have discussed it with AH Spares and a Restorer but all to no avail.
Any ideas please?
Any ideas please?
Hi Guest!
