Trevor Triumph
My Spitfire has a single rail transmission with J overdrive. I bought a new speedo cable, the proper length. When installed the speedo doesn't register. I just had the speedo and tach repaired so i don't think the speedo is the problem. When I put a piece of cable in the angle drive, I can see it rotate as I drive the car. But when the cable is attached there is no movement. The cable is from Victoria British and theier stuff is usually good. I wonder why that is.
T.T.
T.T.
