This morning, just for fun, I decided to do a little unscientific ISO / Noise test with my 5D Mark IV. It's advertised as having pretty good high-ISO performance, so I just wanted to see how the noise was affected as I increased ISO. In this series of shots, I was in Av Mode at f4.0. I adjusted the ISO from 100 up to 32000. (somehow I skipped over 3200). I didn't adjust in fine increments as I just wanted to get rough idea of ISO/noise performance. Note the first couple images were very slow shutter and were hand held, so not the sharpest images to be sure. Note that all were shot in RAW but exported as .JPG, limiting the size to 3M so as to allow uploading here. The exception is the very last image. I shot that as JPG to see the effects of my in-camera "High ISO Noise Reduction" settings (which only works if you're shooting .JPG - no processing is done on RAW images). You can compare the last 2 pictures, both shot at 32000 and see a significant improvement when using High ISO NR. To my eye, the noise is acceptable all the way up to 6400. Even at 32000, when I used High ISO NR it isn't terrible. NOTE: If you click on an image it will open large to see noise better)
