Gerard
Many of you have done this conversion, some of you have future plans for one. Some of you have had or will have trouble using the original metal shift cans because they can interfere with getting the car in gear. If that's the case you will need to use the later style "gaiter solution" from post '72 cars. The problem is the metal hold down rings are NLA and haven't been available for a decade or more. The gaiters are still produced however.
I have the pictured part available as an identical replacement in aluminum. It can be polished to a chrome finish, painted or used as is with the grained finish.
Available with or without original pre-drilled holes.
