Hi, I swear by standard NGK plugs.
I saw independent research in the past that showed NGK better in dyno testing than other brands and, at the same time, debunked some of the expensive multi-tipped plugs as a waste of money. Over the years I've tried any number of brands and never found anything that works better in most cars and motorcycles.
I'm not sure the specific NGK used in your car, but any store that stocks them should be able to look it up for you. If you do a lot of slow speed, around town driving, you might want one step hotter plug. If you are mostly on the freeway at consistently higher speeds, one step cooler might be better.
Preparing for an emissions test, I recently put a new set of NGKs in my Land Rover. The old set being replaced were Champion "Truck Plugs" and were the only thing available when I needed a set about 500 miles from home. That was an emergency replacement because the car began running very poorly after a couple days on the highway. It turned out I'd burnt up at least two of the previous set of platinum plugs, which were recommended by the dealer and really only had about 10,000 miles on them.
I can't say the NGKs are running any smoother than the Champion truck plugs, which were in the car for about 20,000 miles. But, I have had an immediate increase in gas mileage of 10, 15% or better. That might indicate the motor is running stronger, burning fuel more efficiently. I did note the main difference with the truck plugs was a longer electrode, which might have protruded into the combustion chamber and disrupted gas flow. And, I cleaned all the plug wires (8.5mm Magnecor, which are excellent) and applied new dielectric grease on all connections. So, to be honest, there are a couple other possible reasons for the improvement.
But, I can tell you I'll not try platinum plugs in the Land Rover again (They worked great in a couple VWs I had, though). And, I'd say with the "truck plugs", the motor ran smoothly, but gas mileage went to heck. I figure the Land Rover is a good test for spark plugs, since it's pretty hard on them with it's high energy system and coil per cylinder setup.
So, I'm back to NGKs with yet another car! I'd definitely recommend them in most instances and I'll be putting a set in my TR4 when I get done with the rebuild.
