I noticed a post that asked about spark plugs for the TR2-4 engines & the mention of NGK BP6ES.
Being a race engine builder i have tested many spark plugs. It is true that the BP6ES works nicely--up to a point.
The biggest problem using the long reach plugs like the BP6ES is that the end of the plug protrudes to far into the chamber protruding out past the thread in the head itself.
This in turn has a dramatic effect on the cooling of the spark plug which can only be cooled by the incoming air/fuel charge & the contact surface of the thread in the head. If the plug protrudes past the length of the thread it will not cool sufficiently & at higher rpm levels the end of the plug can glow red with the extra heat & poor cooling contact area. If you have a look at how the plugs fit into the head you will notice there is not much metal around the plug thread for cooling as is.
As you can imagine the last thing we need is the fresh fuel/air charge to come into contact with an already glowing hot spark plug & many unwanted things can & will result. Pre ignition & lead fouling, pinging etc.
For this reason we use the NGK-B8HS exclusively in our engines--short reach & the plug cooling is great. Road cars may need to go to one step hotter than the B8HS
Hope this helps
Hope this helps
Hi Guest!
