AUSMHLY
Per Gary Anderson and Roger Moment's Authentic Restoration Guide, page 155:
"The spark plug wires to the first and second cylinders, and those to the fifth and sixth cylinders, were gathered together between the distributor and the engine with black rubber O-rings approximately 1/2 inch in outside diameter."
See attached photo, where I have done this.
I read this about MSD Wire Separators:
Not only do separators have to keep spark plug wires away from engine heat sources, they also have to keep the plug wires far enough apart to prevent inductive crossfire and actual spark loss. MSD wire separators will clean up your vehicle.
See photo include here, with red wires.
Will using the O-rings really cause inductive crossfire?
What do you think, engineer type guys.
Looking forward to hearing your thoughts.
Cheers,
Roger
Cheers,
Roger
