Morris
Okay, so my car has been doing weird things lately. It surges when cruising through town. And on the highway, it is experiencing radically shifting AFR (air/fuel ratio). Coupled with this is an erratic vaccum signal which bounces up and down a few CmHg then settles, then bounces around.
I checked for vaccum leaks as well as checked timing and compression. Everything looks good. I checked the plugs. They had a thick reddish brown coating (indicating a good clean burn, right?) which I removed with a wire brush. After I did this, the vaccum signal and idle seemed much more stable.
I have a new generic brand coil and an old Luminition system. I am running Bosch Platinum plugs gapped to .31.
This one really has me stumped. Do any of your brilliant minds have any ideas as to where I should look next?
