DaveCooper
I have a 74 Elite with stock ignition. The main Jensen-Healey site has a self-described expert who raves about the MSD spark booster on the Lotus 907 engine, even with the stock points distributor.
Do any of you have actual experience comparing the stock (points) set up to the MSD with no other mods? Or, Pertronix's similar Second Strike gizmo to the stock ignition with no other mods?
Do these do much more than smooth out the idle and/or low rpm running? The MSD apparently cuts out at 3,000 rpm, so I don't see how performance would be that much affected; the Second Strike apparently works all the way up the curve.
If the spark boosters added that much, I would expect them to show up as stock in the later versions of the 907, or the Esprit. Are they worth the $200-$300?
Dave
Dave
