Hi all
I am getting dangerously close to getting my BN1 'dependable'.
Having fixed the cylinder head gasket (well from a water leaking perspective but still need to check compression ratios)the core plugs seem to be weeping pretty heavily.
Having read previous posting the screwable, Dorman or 'temporary rubber' seem a godd limited access solution. Does anyone know where you can get them in the UK ?
Also the windscreen keeps creeping up the post on the drivers side and becoming loose. Is there a good fix for this other than cranking up the large circular securing nut. I am getting nervous to do it any more since the passenger side sees to stay put with normal hand tension
Thanks as always for your greta insights
Ian
Ian
