sore but happy
fmichaels
i started my tranny rebuild last night. this morning, my finger tips on at least 7 fingers are hurt'n bad. it's all due to the double plunger lockwasher that secures second gear. now let me say that i didn't really have to remove this gear, but it was the last thing on the shaft and it contains needle bearings, so i wanted to make sure there was no damage or dirt.
getting the lockwasher out wasn't too bad, but reinstalling it was impossible. i spent two-hours and used every profanity i had trying to get the d-plunger back in. if you've never seen this arrangement, the mainshaft uses a series of spring loaded plungers and washers to lock the gears onto the shaft. for the d-plunger, its a single hole through the shaft with plungers on either side sharing a common spring. the trick is too compress both plungers and drop and rotate the lockwasher onto the shaft. easier said than done. (oh and BTW, the washer sits down inside a lip from the cone of the gear so it's not a simple matter of pushing the plungers in)
after 2 hours i knew i wasn't going to get this washer in. i had read all of my reference books and didn't see anything that helped. haynes just said to push the plunger (note singular) in and rotate the washer (yeah right!). then i read a small picture caption in my practice classics book in an article by joss joselyn. i had to read the caption a couple times but it referenced a hardy engineering trick for getting this washer in. What hardy did was to cut a small notch (they called it a nick) in the underside of the washer to allow more room to get, in my case, a dental pick on the plunger.
well i read it many times and hesitated since i don't like adding notches to things that didn't come with a notch to begin with. i eventually got out the dremel and cut the small notch just as the book said. well, with the notch and a dental pick, it worked like a charm with no ill effects. if only i would have read this 2 hours earlier.
not to belabor my story i also tackled the balls and springs on the 1st/2nd syncro hub. i bought a 2" PVC street elbow from home depot and cut off about 1/2" of the female flange. this gave me a 1/2" thick ring. i then cut the ring once such that the ring could be expanded. i marked the ring at the areas where the balls were located and took my dremel and put a notch (detent) on the inside of the ring for the balls to sit in. i slipped the ring over the syncro and carefully pushed the spring and balls in one at a time. after that, it was a simple matter of sliding the 1st gear over the hub and pressing it down capturing the balls. and i thought that was going to be my hardest task.
anyway, the mainshaft is done and after my fingers heal a bit, i will begin the first motion shaft.
Someone here reported that his girl friend did that trick with a hair pin, hehe.
Glad you only have sore fingers and everything is together.
yeah .. i shot a couple of those ballbearings across the basement, but all is in and looking good. i can see the role that the balls and springs play now in a working trans. if they get gupped up and stick it could cause problems. the rest of the tranny should be straighforward and alot more fun. it's also nice not to fear this beast anymore.
Well at least we know where to send our trannys for some tender loveing care.
That was the Doc's better half.
Someone also noted a hose clamp.
Glad to hear it is all back together.
Good job. /bcforum/images/%%GRAEMLIN_URL%%/thumbsup.gif
Stuart. /bcforum/images/%%GRAEMLIN_URL%%/cheers.gif
Yup-yup. First Wife. The needle bearings on the snoot of the first motion shaft held in place with grease and a small diameter rubber band she had for her pigtails. The band dissolves with no ill effect. The band clamp for the three balls on the gear cluster. Like a piston ring compressor.
Glad to hear you've gone thru the gearbox thoroughly Fred!
