jlaird
Page 172 Para 8.3
Disconnect the leads from temninals D and F on the dynamo and the join the terminals together with a short length of wire. attach to the center of this length of wire the negitive clip of a 0 to 20 volts voltmeter and the other clip to earth. Start the engine and allow it to idle at about 750 RPM. At this speed the dynamo should give a reading of about 15 bolts on the voltmeter.
But but it is not hooked up to the dynamo, how the heck could you read the output?
Should the output not be read across the two terminals on the generator with out it being hooked to any wires?
