Hey guys, hope you can help... bought this herald about 8 months ago and it has some issues... any comments on the following question would be helpful..
1. Driver door is mis-aligned... when I got it the bottom back corner of the door sat out about an inch.. I have loosened all the bolts and used shims to realign the door and just can't get it back to alignment.. How do I determine if it is the door or body work (fender, sill, ect.) that is the problem.. this is a pretty straight, rust free car... don't know how to decide which it is.. wish I had another door!!
2. Compression check gives me front to back 100, 90, 95, 85 lb/sqinch, rebuild time or can I still go with this??
3. Taking the dash out @#@#@#@!!! what a bear... so do I really have to unhook all the cables from the engine side and bring through?? can't see where I can get the knobs off at the dash..
Well that is it right now.. thanks for any comments...
Jack /ubbthreads/images/graemlins/nopity.gif
