burgundyben
So we've had the car (MGA1500) about 10 days, this weekend we shot off to a vintage hill climb, about 100 miles from home.
I got the carbs about right, mixture is close although but I think out of balance, will come back to that after our hols. Want to pull a plug and see the colour.
Questions.
1. At about 3700 revs cruising we seem to be doing about 60 mph, this seems very slow for such high revs, a criticism of the MGA I have read somewhere, can I get a taller crown wheel and pinion?
2. On a consistent run at 3500 to 4000 revs the oil pressure drops to a shade under 40 psi (just had clean good quality 20/50 put in it), this sound ok?
3. I ran through the tappets as I thought she sounded a bit tappety, all at 16thou/0.4mm, but at motorway speeds she sounds very noisey from the top end, I have not run the engine with the rocker cover off, I'll do that and see how much oil there is coming up. why so much noise from the top end? Are they just like that?
Questions.
