lesingepsycho
I swapped back to my SUs and now I'm getting a serious bogging/see-saw on take-off or on high load/low RPM acceleration. It occurs mostly from 1000 to 2000 RPM at part throttle. If I go full throttle off the line, there is no bogging. But even if I'm rolling and give it part throttle, say less than half, I can hear the carbs sucking like crazy but the engine bogs down and and the car see-saws. If I'm sitting in neutral and rev the engine, it is plenty responsive however with no sign of bogging.
They are complete matched rebuilds including shafts, jets and needles. I've balanced air flow many times using a uni-sync, and matched the jets for turns. I can't find any vacuum leaks but if I give it choke, i.e. more jet, then it takes away some or all of the bogging/see-sawing. The problem there is that I'm already running at 14 flats out and it seems to be running rich even with the choke off so I'm not sure more jet is the answer.
Anybody? Any advice will be appreciated. I don't want to give up on the SUs as they are great when they're functioning properly, but right now....
JACK
JACK
