jehuie
I need some tips on cleaning this wiring up. Someone (my late father) rewired it this way and it has worked for many years. The alternator recently stopped charging the battery and I have to make a decision on whether to try to get this mess working again....or to try to put it back to use the control box again. The original 1960 Morris minor engine has been swapped out and it now has a 1275 from what I suspect was from a Sprite.
So my questions are many but to start with:
1) Will the control box on the Morris Minor work with this newer engine/alternator if I was to try to move it back?
2) Is there a way to test that control box to see if it's still working properly? I'm assuming it was all bypassed for a reason.
3) Should I try to get it working again as it is currently wired prior to trying to restore it to the original?
I found my dad's old diagram he drew up for how he has it wired now...but it seems to be not entirely accurate:
