Solid core insulated vinyl siding significantly deadens sounds coming from outside of the home. It’s a perfect fit for a wide variety of home styles, whether the project calls for all-over siding or an exciting accent. Our solid core vinyl siding is virtually maintenance-free, and it reduces thermal conductivity. Proprietary lamination technology creates an extremely strong bond between panel and insulation, and an authentic, straight-face design lends the clean look of hand-milled cedar grain.
All American Window solid core insulated vinyl siding https://allamericanwindow.com/siding/solid-core-siding/ is available in straight boards only.
Learn about our Solid Core insulated siding and all the benefits you'll receive by choosing it for your home.
Virtually maintenance-free vinyl siding.
Lifetime guarantee on your siding and installation.
Premium panel siding won’t rust, crack, peel, rot, dent and resists fading.
Overlapping nailing hem with an extra .092” rollover for extra strength.
Extra-long 16’ panels to create fewer seams.
64% greater impact resistance than traditional vinyl siding.
45% more noise reduction compared to non-insulated vinyl siding.
19% better R-value (insulation) depending on profile.
Designed to resist winds up to 160 mph.
Features moisture-management ridges that provide space for ventilation.
When you’re updating your siding, you’re installing a first impression that you’ll see from the moment your home is in view, to the moment you walk up to the door. We understand that its important to receive a quality value for the cost of your siding, however, due to your homes customized specifications the cost of Champion’s siding products and services will vary.
During our in-home consultations, our customer care associates will work with you to help discover the best options and savings opportunities for your home. We’ll discuss your homes uniquely customized needs, materials, and various other options that will help to improve the quality, durability, comfort, savings and overall beauty of your home.
Once we’ve been able to determine the right options for your home’s roofing needs, we can better determine an exact price. We can also provide many easy and affordable financing offers to help choose the best financing solution for you.
