Hello Hegg,
I don't know the Elan, is the solenoid seperate from the starter? Usually it means that there is insufficinet voltage to pull it in, low battery, poor connections at the battery, earth or the solenoid.
Does your selenoid have the start button for remote starting? That would be selenoids mounted on the firewall.
That button will bypass the low current side of the selenoid and the car will spin over if the power is there. ( watch out, it will spin over even with the key off, so have the car in neutral..) If the car doesn't spin then it's a battery juice problem for sure.
That's funny, my button is on top. Wouldn't surprise me if I have mounted my selenoid the wrong way! ( If there is a way to make it work the wrong way, I'll find it..)
