...in being able to drain the radiator without sending antifreeze everywhere. I went to change out my thermostat last night and figured it would be a good time to put some fresh antifreeze into the system. Most radiator's I've dealt with in the past had a drain petcock. I couldn't find one. I did find a bolt on the bottom that may have been a petcock, but it was inaccessible because of the fan shroud. I decided to drain it from the lower radiator hose and stick a bucket underneath, and I should be able to catch all the antifreeze, right? Wrong. "Baby Blue" had other plans for me and spat out a fair amount of antifreeze onto the garage floor. I caught about 1/2 the antifreeze with the bucket. The rest I had to clean up.
The thermostat gasket was stubborn to release, but I got the housing off and reassembled everything without incident. I was kind of surprised that I only used about a third of a gallon to replenish the antifreeze lost. I guess the rest was still in the engine and heater core?
There's definitely a learning curve when it comes to working on the Sprite, but luckily "Baby Blue" is very forgiving of my current ham-handed mechanics. When she doesn't forgive, there is always Victoria British
