A couple of years ago, I had rebuilt the engine in my 78 Spitfire. I wanted to "pep it up" a bit, so I replaced the stock pistons with .030" over flat-top (euro spec) pistons, installed a hotter cam, dual webber DCOE carbs, headers and an Ansa exhaust. I also removed all the smog equipment. After getting it all back together, it seemed to run ok, but I was disappointed that it didn't have as much "zip" as I thought it would have with all the mods I did. Anyway, I drove it like that for a couple of years until by son took it out once night and two of the push rods popped off the rocker arms and got bent. That gave me an excuse to pull the engine and tear it apart (I had been wanting to replace the rear seal anyway). What I discovered was that the cam timing was off one tooth and probably had been since I first rebuilt the engine. My expectation now is that my little Spit will run like a Banshie now that I have the cam timing right! (I hope so anyway). I will keep you all posted on the outcome.
