Ok. First of all...I'm guessing that the switch for the brake lights is located below where the coil mounts. Is the switch mechanic or electric? I'm guessing mechanical by looking at it. If so, that's good news. The little "pin" thingy seems to be seized inside...
Second...I have a '79 Midg and am trying to diagnose some ignition (at least, I think they are ignition) issues. The dizzy has one wire that runs from it the coil(That's the only wire that I can see). The coil has that wire and one that runs into the wiring harness (I'm guessing to the starter solenoid?). I have like two wires and one plug just hanging out in that general area. Are these for a diferent dizzy? I guess what I need to know is what should I have coming off the dizzy and coil...
Third...Thanks for the link to the article on water chokes. I believe I have issues with that too...
