TypeRboy
... and it runs awesome! Everything works except the speedo ( What is it with me and speedo's? The lotus speedo refuses to work as well..) The suspension is just the right firmness, and ride height is perfect..( and adjustable of course..
The vented front discs stop just great, and the handling is very sharp for a car this old. The motor and trans just purr along ( you certainly couldn't call 59 HP a growl..)
I am getting asked about the car everywhere I go, even though it still has the old original faded out blue paint.
This car would be tons of fun with some serious power, so to that end work on the BDA is progressing at a much faster pace. I've sorted out a clutch for the aluminum flywheel, and found ign wires and a toothed water pump pully for it, and the cams are timed in. I just need to weld up my header and make a throttle linkage, and I'll be ready to slip it in. This means that I will have a nice running 1500 and 4 speed with 36K on them if anybody is needing them..
Hi Guest!
