lesingepsycho
...you really should use a straight-edge when changing your timing gears. /bcforum/images/%%GRAEMLIN_URL%%/blush.gif
When hurriedly changing my timing gears some time ago, I thought to myself, gee, I can just eyeball this one because if it were off, it would be off by a noticable amount.
Wrong!
The low compression numbers and charge coming back through the newly tuned carbs is what tipped me off although the car idle well and ran strong (enough).
My timing chain cover was leaking after the new gears went in so luckily I had a reason to get back in there. Checked it with a straight-edge this time. /bcforum/images/%%GRAEMLIN_URL%%/wink.gif Now it runs even stronger /bcforum/images/%%GRAEMLIN_URL%%/laugh.gif Lesson learned.
JACK
Wrong!
JACK
