TRclassic3
I recently installed professionally rebuilt ZS carbs on late TR6 engine. I'm having an issue I hope to get some advice on. After running at speed, say 2500 to 3000 rpm, and then coming to a stop, the rpm is very slow to drop to normal idle. I would say it takes about 10 seconds to settle down. The problem is also evident when up shifting, as the rpm stays high between gears. I have inspected the linkage and don't find that it is hanging up anywhere. Is it possible though that it could be something with the way I reinstalled the linkage? Or could it be that the vacumn advance is not functioning properly, or????
I have tried ATF and 20w in the dash pots. no difference.
